Cascade introduces largest roll clamp
- 19 Apr 2007 ( #306 ) - PORTLAND, OR, United States
Cascade's 120H pivot arm roll clamp
Cascade Corp has added to its G-Series rotators and introduced the largest capacity roll clamp it has ever marketed.
The 80G and 100G rotators have 8,000lb and 10,000lb (3,628.7kg and 4,535.9kg) capacities respectively.
Cascade Corp corporate communications manager Madalyn Piar-Katter said: "We redesigned our rotator line to include a visibility window. It helps the forklift driver work more efficiently and with less damage [because the driver can] see the load when moving."
Cascade has also introduced 120H pivot arm roll clamps for lifting heavy loads. The 120H replaces the 195F model that represented the imperial measurement of 19,500lb (8,845.1kg) capacity. The 120H has a 12 ton metric rating capacity.
Cascade Europe, based in Almere, the Netherlands, has introduced G-series multiple load handlers. The new design has an all-steel frame and can accommodate different pallet sizes.
Briggs adds Maximal range
Meet Cascade's Jim Faran, Your Go-To Forklift Guy Advertisement - 21 Aug 2025 - 1 min read
Smarter Handling: Cascade’s Newest Efficient Tech Advertisement - 1 May 2025 - 4 min read
VETTER Industrie GmbH
