Jayline – Fork Protectors and Load Protectors
- 29 Jun 2006 ( #266 )
4 min read
Q. Give a brief description of your products:
Jayline has invented a very special heel device that fits to the forks in minutes that virtually eliminates fork wear. In addition we have invented options that prevent load damage.
Q. These products are marketed to which industries and for what applications?
Fork Protectors - Solution 1 (top) & Solution 2 (bottom)
The fork protectors are extremely valuable in any industry and application where the forklifts are receiving heavy workloads and especially where they are working on hard surfaces. The load protector options are essential in industries where loads are fragile for whatever reason. Most loads need to be protected from rough treatment and from forklifts that are operating at good speeds. Examples are the white goods industries, foods, flowers, electronics, paper, furniture, retail, freight forwarding and docks etc...Let's face it fork trucks are a means to move goods and assets easily and economically. Unfortunately, in the process, the truck and often the load can get damaged. This means increased cost and reduced profit.
In the face of ever more stringent legislation and inspection procedures, wear to the forks of a truck will mean that they will have to be replaced before that truck can continue operating.
With even the smallest forks costing from upwards of £150 a piece that can add up to a sizeable dent in profits each time it happens, not to mention the cost of down-time. Wear to the forks is virtually inevitable when a truck is in regular use, no matter how conscientious the driver is.
And damaged loads just simply mean less profit. So, if worn forks or damaged loads are denting your profits these products will help you save thousands on fork maintenance and damaged loads!
Q. What makes your product outstanding?
They are very easy to fit; can extend fork life almost indefinitely; require no truck modification so no warranty implications; include design options to protect your valuable loads; feature tough "built to last" construction; are delivered fast to your door and they are backed with free advice and telephone support.
Q. Are there different problems and different solutions?
Fork and Load Protectors Solution 3
Fork Protectors (Solution 1)
In certain environments where damage to loads is unlikely or not as critical, this base level option provides maximum fork protection and represents excellent value for money. Made from special cast steel and easily fitted in minutes with high tensile steel bolts, Jayline Fork Protectors prevent forks from dragging on the ground.
When worn, the protectors are adjustable and then reversible so that they can continue to offer protection to the forks. Jayline estimates that up to 10 sets of forks can be saved from replacement before the protectors themselves need replacing.
This option can be upgraded, if required, with additional Load Protection Pads.
Fork Protectors with inbuilt Load Protection (Solution 2)
These revolutionary patented protectors mean your forks will last almost indefinitely but also have the added feature of carefully designed inbuilt rubber inserts that help reduce impact and so protect valuable loads and assets from collision damage with the fork carriage. This option can also be further upgraded, if required, with additional Load Protection Pads for even greater load protection.
Fork and Load Protectors Heavy Duty (Solution 3)
Combined with either Standard Fork Protectors or the Fork Protectors with inbuilt rubber inserts our moulded Load Protection Pads could dramatically reduce damage to your precious loads. This product combination offers massive savings potential. With a full set of Fork and Load Protectors who knows how much you could save year after year.
This combination of Jayline products offers the ultimate solution, maximum fork protection - minimum load damage.
Fork Protectors - Solution 2
Load Protection Pads (Solution 4)
Where fork protection is, just simply, not an issue but where load protection is important, the Jayline Load Protection Pads are an ideal solution. Available in pairs, as a stand alone option, they are a proven solution to the costly problem of load damage.
Costs and savings:
At £65 for a pair of 4 inch (105mm) Standard Fork Protectors you could save at least £1500 for every truck you run. The potential savings on 5 inch, 6 inch and 8 inch forks, not to mention special forks and attachments, is far greater than this.
With the additional savings in damage to loads, who knows how much that can mean?
Q. Tell us your future plans for market expansion or product enhancement:
Jayline Fork Protectors and Load Protectors have been sold around the UK and Keytroller Inc. has already been appointed as the distributor for the Americas. We are now ready and looking for distributors elsewhere around the world.
Interested in becoming a Distributor?
Click here to see Jayline's contact details on their ShopFront
This is a major breakthrough from Jayline Products and something that every operator of fork trucks needs to know about. For more information and full details of size availability and costs contact: www.jaylineproducts.co.uk
