yale transmission removal
removed engine. removed all dif bolts. dif is apart aprx 3/16 but will not come any further. its almost as if a pilot bearing is holding it but it doesnt have one being an automatic. is there a bolt or pin that has to be removed ???? HELP
  • Posted 12 Apr 2022 01:11
  • By csirandy
  • joined 12 Apr'22 - 2 messages
appleman
I see you are trying to remove the transmission why are you trying to take the rear off why don't you wheel the trans out from the frame remove the bolts on the side to the frame undo the brake cables and lines take it out complete and then rebuild to change packs the rear does not have to be touched all parts come out from front unless the pinion gear is bad or spider gears or leak at pinion hope this helps
  • Posted 17 Apr 2022 02:28
  • By Scott_
Scott
axels still in?
  • Posted 14 Apr 2022 22:49
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
