Hi could I get a copy of the error list please. I have one with multiple codes on the display
Error 241 on node 038 and on node 006
Error 220 on node 038 and 006
228 on node 033
227 on node 001
Error 008 on node 033
Thanks in advance
Olá Roberto
Poderia me passar a lista de erros da yale MR16n
[email address removed]
67984341110
Att
Same problems to me fault codes is 227-01 equipment not working model (Mr16hd) serial number (D849TO2016m) plz say solutions
send me model and complet serial number
i wil send you the complet error list
It's long time since I've seen this question come up, and the info has slowly seeped back into this brain of mine.
First you will need a sappy hand held analizer unit. First all those fault codes you see in the canbus need deleting then start and use the truck
The first code that reappears is where the problem lies, if it points to canbus error then change the canbus, if it says joystick problem then check out the joystick, this joystick has a lot todo reach in and out hoist and lower also the horn is incorporated. The unit is made up with lots of micro mini switches. Anything that small is prone to wear and breakage, the wiring on these trucks is quite reliable I can't ever remember having to repair wiring on these trucks and normally they are quite reliable. If you don't have a zappy diagnostic had held unit, then you may have to get a Yale tech in with his laptop to delete codes.
Not really familiar with this model but, if you are seeing stacked Canbus errors you need to do a diagnostic check on the Can loop. If the can loop opens the truck will not finish it's start up sequence. This will cause a continuous string of can errors. Make sure the termination resistors are good also.
