Hello, I just acquired two MPW060LEN24T2748 used pallet trucks but I have not been able to make them work properly. One pallet truck does not lift, it only beeps when pressing the lift buttons. Everything else works correctly. The other pallet truck has battery problems which I have yet to check them aswell as they do not charge properly either. If anyone could send me an electrical manual or parts manual or have any idea that can help I would appreciate it, thanks.
Charge the battery !!!!!!!!!!!!!!!
I got 24.56volts on the batteries
Look after your battery idicator try A another one,
It is possible that your battery indicator have A problem, internal A relais is stuc broken its thinks battery is 20% it will not lift.
Regards
John.
What is the actual battery voltage that you can measure with your meter?
The MPW060 runs properly, I can drive it, but I cannot lift, is this still a problem with the battery?
load you battery propely
fault is gone
regards
john.
Battery,battery,battery!!!!!!!
