Yale glp060 fault code
Vsm524213- 1 #126
First 4267 last 4728
Did the pm then the wrench light came on a week later. Went into the fault log and found code listed above. I do not have the software or manual to found out code information.
Any help?
  • Posted 31 Jan 2014 03:37
  • By Rmullis
  • joined 8 Jan'14 - 15 messages
Russell mullis
Atlantic Forklift Services
Charlotte, Nc
Mullis.russell@gmail.com
7042967564
DTC 524213-1 - Horn Alarm Output Driver OC
1- HORN OUTPUT DRIVER SHORT TO BATTERY
2- HORN OUTPUT DRIVER SHORT TO GROUND
3- HORN OUTPUT DRIVER OPEN CIRCUIT
4- VSM FUNCTIONAL FAILURE
If DTC 524213-1, go to Cause 3
CAUSE 3 - HORN OUTPUT DRIVER OPEN CIRCUIT
PROCEDURE OR ACTION:
1. Turn truck power OFF.
2. Disconnect the indicated connectors at horn and VSM.
3. On the DMM, select ohms scale. Verify DMM zero reading.
4. Measure resistance between the horn output driver pins at each of the indicated connectors.
Is resistance less than 0.5 ohms?
YES: Go to Cause 4.
NO: The horn output driver wire is shorted to ground. Locate and repair/replace shorted wire/connection.
CAUSE 4 - VSM FUNCTIONAL FAILURE
2. Reconnect harness connectors to horn and VSM.
3. Turn truck power ON and check DTC display.
Did DTC reoccur?
YES: Replace the VSM.
NO: Problem corrected. Resume operation.
Basically Cause 4 is VSM failure if previous check and repair does not fix problem.
  • Posted 31 Jan 2014 07:55
The largest butterfly in the world is the Queen Alexandra's Birdwing (ornithoptera alexandrae), with a wingspan of up to 31cm (just over 12 inches). It is an endangered species only found in Papua New Guinea.
edition #1301 - 1 October 2026
Forkliftaction News is excited to launch our Big Picture Interviews. In this thought-provoking series, we ask industry leaders for their insights on current market dynamics. In this week’s interview , Ralph Cox, Toyota Material Handling Europe’s SVP market operations, talks about why lean manufacturing and automation go hand-in-hand. Keep an eye out for the fortnightly interviews... Continue reading
Autolift E180AT36B-D5-180
Mitsubishi Logisnext FD25T5M
November 10-12, 2026 - Marina Bay Sands, Singapore
September 16-18, 2026 - Guangzhou, China
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Mohammed Kabir Mohammed Kabir
Chief executive officer, Corvus Robotics
Regional sales manager, Abbey Attachments
vice president of human resources, Big Joe Forklifts
Board of Directors, UKMHA
