Won't start w/o starting fluid
I just purchased a Hyster H50H serial#D3T2202Y
Recent tuneup, good compression, good spark, it needs starting fluid to start and then it will run fine. I'm pretty good with engines but no experience with propane powered. Where should I start?
Thank you
  • Posted 15 Jun 2017 00:25
  • By chad_p
  • joined 15 Jun'17 - 4 messages
  • Washington, United States
Thank you, I'll give it a shot when I take delivery
  • Posted 15 Jun 2017 09:09
  • By chad_p
Am thinking this is the D003xxxxx serial number....as for being a lpg engine one thing to check would be the idle mixture adjustment...on the side of the "carb" where the lpg hose comes in from the vaporizor,there should be a large screw....turn this in all the way till it bottoms out then back it out 2 full turns to start..with engine running adjust as neccisary to get a good smooth idle...
  • Posted 15 Jun 2017 09:01
  • By kevin_t
That's the serial number that's printed on the nomenclature tag. It's a propane 4 cyl. I honestly don't know much more about it as I just bought it and the previous owner is looking for the paperwork.
  • Posted 15 Jun 2017 08:42
  • By chad_p
Serial number looks odd is that a correct serial number...what is the FULL Make,Model AND SERIAL NUMBER? also is it gasoline,LPG or diesel????? And what size engine...4,6 cylinders??l
  • Posted 15 Jun 2017 05:51
  • By kevin_t
I assume you're asking about the fuel system? I can find out later when i get back to the shop. How many systems are there? How would I be able to tell what system I have?
  • Posted 15 Jun 2017 03:03
  • By chad_p
What system does it have on it?
  • Posted 15 Jun 2017 02:55
  • By BREWSKI
RAEDER-VOGEL
