Won't Run
I have an Error code 09-1 and the lift will sometimes crank and run for hours then other times it will not crank at all. Seems to be starving for fuel. At an idle it will surge sometimes then it may run fine at an idle. Sometimes i can feel a skip here and there. Replace dist. cap and button, regulator, fuel solenoid, and spark plugs. Anybody seen this before? It is an LPG forklift btw
  • Posted 27 Oct 2017 00:59
  • By Droof
  • joined 27 Oct'17 - 4 messages
DROOF
Truck turns over and tries to run but once I let the key return to run from start it dies and shows code 09-1
  • Posted 30 Nov 2017 13:25
  • By Droof
If truck wont crank over at all i would be looking at battery,cables,starter and starter solenoid and any relays/fuses for circuit
  • Posted 30 Nov 2017 13:23
  • By kevin_t
Still having the same issue with this lift. Replace the wires to distributor and the entire distributor. No change. It will not crank at all at this time. Timing is good. Has spark. Has fuel but im not sure if it is enough fuel or too much. Still wont run.
  • Posted 30 Nov 2017 06:28
  • By Droof
I have looked all over the wires in the harness but i cant get the distributor out to check wiring actually on the distributor. Let me look over it again today thought. Thanks!!
  • Posted 31 Oct 2017 01:13
  • By Droof
09-1 is code for ignition signal abnormality...i would check connector from ignitor to coil for broken wires and pin fittment...check where wires go into distributor especially
  • Posted 27 Oct 2017 06:56
  • By kevin_t
