Won't Reach In
Looking at a Linde R20 S/N G1X113K01760 - 1999
Hydraulic valve solenoid for reach out function is becoming powered (and consequently opening spool for reach out) when hydraulic lever is pulled, irrespective of which lever is pulled. As a consequence the reach carriage wants to remain permanently reached out.
We've swapped the levers, remains the same.
Swapped the coils on the reach valve front to back, makes no difference.
Checked the valve block assembly and can't find fault.
Swapped the outlet pipes to reach cylinder and the fault reverses (i.e. will want to reach in all the time).
Swapped the Hydraulic Control module, remains the same.
All wiring looks in good order with no signs of chafing or damage.
Only fault codes showing are 2, 3 & 9 which all disappear when drive engaged.
Anybody got any ideas, anybody come across this before ?
Any help would be greatly appreciated.
  • Posted 9 Mar 2018 02:52
  • By Dez_A
  • joined 3 Jun'04 - 88 messages
  • Middlesex, United Kingdom
Service life of a forklift is proportional to how well it is maintained.
A quick follow up on this post.....
Lindetech, spot on, damaged wiring loom that would never have been found simply by visually inspecting. Had to cut out the hosing covering the wiring loom and then found wires chaffed and short circuiting inside. A very kind thanks to a Forklift Action member for sending us the wiring diagram. Problem solved.
  • Posted 29 Mar 2018 18:15
  • By Dez_A
Hi Lindetech, thanks for your input. We have 4 separate levers all the same part number, swapping levers around doesn't make a difference to the fault.
Reference wiring fault, without a wiring diagram it's difficult to understand exactly what should be happening with the circuit, but i think the engineer was saying as soon as any lever is pulled, all of the valve solenoids get 48v supply (don't know if thats correct or not), but guess then the solenoids are switched via the return. Will check further tomorrow.
  • Posted 12 Mar 2018 19:45
  • By Dez_A
Sounds like you may have a wiring issue in the harness from chassis to the reach carriage.
Also check the short harness to the valve assembly
What joysticks do you have?
4 individual or 2 that move fwd/back /left/right
  • Posted 10 Mar 2018 16:46
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Still GX10
Still GX10 2000
Poland
EUR950
Toyota 8FD45
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
Still GX10
Still GX10 2000
Poland
EUR950
Toyota 8FD45
