won't move
I just recently got my Clark C-500-45 forklift running and have been working on other odds and ends. I went to move it and it doesn't want to move forward or reverse. I don't think the trans is slipping but almost like the brakes are holding it back. I did notice the e-brake cable was frozen and seemed to be holding up the lever on the small brake drum underneath so I removed the cable but it didn't seem to help. Are there common problems with the brakes that cause this issue? This forklift had been sitting for about 5 years. Thanks
  • Posted 24 Feb 2014 13:34
  • By loadedgoat65
  • joined 31 Jan'14 - 12 messages
  • Posted 20 Oct 2025 18:22
  • By steve_jon
  • joined 17 Oct'25 - 1 message
121892 wheel cylinder
1763662 cable
  • Posted 3 Mar 2014 22:00
I ended up pulling apart the right brake assembly and found the wheel cylinder frozen. Does anyone know the part # on the wheel cylinder on this lift? Also need a parking brake cable that is also frozen if anyone knows the part # on that too. Thanks
  • Posted 3 Mar 2014 12:53
  • By loadedgoat65
I raised the front wheels off the ground and the left wheel will turn by hand but the right one is stuck. If I start the lift and put it in drive or reverse the left wheel is the only one that will turn. Do I have a problem in the right brake drum? Thanks
  • Posted 3 Mar 2014 03:34
  • By loadedgoat65
Thank you bbforks I will try that and post my findings.
  • Posted 27 Feb 2014 00:37
  • By loadedgoat65
The first thing to check is how free are the wheels to turn- get the drive wheels off the ground, put a socket on 1 of the lug nuts & try turning the wheels- they shouldn't be that hard to turn by hand.
If it fails that test, disconnect the brake line from the master cylinder on the right side (as seated on the machine) & try the test again. If the wheels turn more easily then either the master cylinder is faulty or the brake actuation rod needs adjusting.
If the wheels turn easily with the first test then you may have a sticking inching valve or a worn trans. Either one of these issues will allow the engine to rev to governed speed as if the trans selector is in neutral. To test these- have lift in open area, block the wheels, rev engine to governed speed- keep engine reved & place trans selector in f or r. At a minimum the engine should bog down under the stress of the engaged trans. If there's really no difference in engine rpm then a trans issue is present. At that point another set of checks are required.
  • Posted 26 Feb 2014 23:37
  • By bbforks
I noticed today that it will move but you really have to push on the accelerator to get it to move but once it warms up it won't move forward or reverse. I've read about a stuck inching valve, is this possible? Thanks
  • Posted 25 Feb 2014 12:06
  • By loadedgoat65
Hello, Brakes are inside the differential. They have a friction style brake shoe adjuster. They will sometimes seize or the shoe might have bonded to the drum. C500 were good trucks. Parts are very reasonable but it is labor intensive for repairs. Good luck
  • Posted 24 Feb 2014 23:23
  • By Prentice
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
REPOWERTEK Inc
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
