wont move, no control lights
model: ERC065ghn48te084
serial no: A908N07914F
We just brought this from an auction. Beacon and head lights work.
Battery volt 48.9v.
Fuses good.
Wont move forward, reverse, forks wont tilt or go up or down.
Control panel wont light up showing charge or codes.
Parking brake and seat switch work.
No master switch.
Removed steering column covers, found they had the two wires going to the ignition jumped together with a loose wire. No wires going to ignition cylinder.
Need some help on where to go from here. No manuals or wiring diagrams.
Thanks
  • Posted 15 Aug 2017 06:53
  • By riley_m
  • joined 15 Aug'17 - 1 message
  • Northwest Territories, Canada
check the battery gate switch
truck wont run if that is not made
also there is a diode block inline with the control circuit in the control panel at connector J17 that may keep truck from powering on correctly.
  • Posted 15 Aug 2017 11:38
  • Modified 15 Aug 2017 11:43 by poster
Hoist Liftruck F180-36BOX-CAR
Mitsubishi FD200
Zhejiang UN Forklift Co., Ltd
