Won't move either direction
Hello everyone. I'm working on this unit s/n 020D-90-31367. The forward and reverse contactors kick in both directions but kick out in few seconds. Codes and recycle key to activate contactors again. there is a box in the contol panel on the right side. it shows a F. code when the contactor trips. Can't find any info on this unit. Wanting to know what the code is and how to check it.
  • Posted 26 Oct 2022 07:12
  • By Hdsprt
  • joined 12 Nov'15 - 43 messages
  • Illinois, United States
20D OR 20I =I THINK 20I NEEDS A SETUP WITH THE UPPER BOX AND BOTTOM BOX=CONTROL HANDLE HAVING A POT TO CHECK THE WIRING
  • Posted 28 Oct 2022 23:42
  • By JKPAINTER
  • joined 26 Jul'17 - 73 messages
F simply means there is a fault, the most likely cause is worn or "stuck" drive motor brushes. Disconnect the battery and remove and inspect the drive motor brushes, clean the armature, and reinstall brushes ensuring they slide freely in there holders.
Hope this helps!
  • Posted 28 Oct 2022 15:48
  • By Mike_Sawchuk
  • joined 28 Oct'22 - 2 messages
  • British Columbia, Canada
Mike
Crown SX3030TT4250
Mitsubishi FGE35AT
Briefs United States
Crown SX3030TT4250
Mitsubishi FGE35AT
