URGENT ASSISTANCE PLEASE: HOW TO FILL POWER STEARING
I HAVE THE KALMAR E-50BX EV TYPE: F. FORK LIFT AND I NEED TO KNOW HOW TO FILL THE POWER STEERING FLUID AND THE PROPER STEPS TO TAKE TO DO SO.
THANK YOU.
-JACK
  • Posted 26 Oct 2013 07:02
  • By JACKPROVOST
  • joined 26 Oct'13 - 2 messages
  • Oregon, United States
THE SALESMEN OF THE YEAR
ehhh good point edwardt
i wasnt paying attention to the date on the post
DOH!
nice catch lol :)
  • Posted 15 Apr 2016 22:23
hopefully they got it fixed before now...
{this was a 2013 posting...}
  • Posted 15 Apr 2016 08:28
Prioity valve fault on orbitral...... Common fault
  • Posted 15 Apr 2016 03:28
  • By MrKalmar
  • joined 30 Mar'15 - 8 messages
  • shropshire, United Kingdom
I think I would first get the steering end up off the ground and see if the binding goes away or is related to the position of the wheels and/or steering hand crank, then, as this is an electric [battery motive] forklift, I would be checking the power steering motor brushes as well as other failure points in the circuit to the power steering motor, like the PS/relay contacts and cables to the power steering motor.
If it has 2 hydraulic pump motors and one is smaller than the other, and the smaller one runs when the truck is in a driving mode, the smaller one will be the PS motor, and in that case, don't bother looking for a priority valve.
if the problem seems to be related to where the steering hand crank is but not in relation to where the steering wheels are pointed, you most likely have a defective/bad "orbitrol" (sometimes called the steering torque generator). If it seems related to where the steering wheels are pointed, you most likely have a mechanical failure in the steering axle.
  • Posted 27 Oct 2013 04:59
  • Modified 27 Oct 2013 23:03 by poster
most lifts today do incorporate the steering function into the hydraulic system. It operates off the auxillary ports of the hydraulic control valve and is controlled by what they call a priority valve that diverts pressure to the steering cylinder when it is called for when turning the orbitrol valve (steering wheel).
- i would first check the auxillary pressure on the hydraulic system, make sure it is at the correct pressure and also remove the relief valve and make sure it is in good working order.
- then find the priority valve and make sure it is not sticking (removal and dissassembly required for this part).
- also check the orbitrol valve there could be a problem there causing the hard steering, in some cases the orbitrol valve has a pressure relief valve on it, it can be removed and checked for broken springs etc.
- lastly you can check the steering cylinder and make sure it is not leaking or bypassing internally.
some of the most common issues with steering generally winds up being a faulty priority valve or some kind of issue with the orbitrol valve.
good luck
  • Posted 26 Oct 2013 21:19
THANK YOU FOR YOUR RESPONSE.
YES THE STEERING IS HARD, IT DOES NOT HAPPEN ALL THE TIME. FLUID LEVELS ON HYDRA IS FULL. ANY ADVICE ON WHAT TO DO NEXT? MOTOR GOING OUT? DIRTY?
THANKS AGAIN FOR YOUR TIME.
  • Posted 26 Oct 2013 08:29
  • By JACKPROVOST
have you looked under the floor?
I would expect it to use the same hydraulic oil as the lifting mechanism.
as long as it lifts fully you don't need to add oil, and only check it with the forks lowered all the way and tilted forward.
what makes you think it is low on oil?
is the steering hard? does the steering motor run? do you hear a contactor click when you turn on the key and have the seat switch closed?
  • Posted 26 Oct 2013 08:25
  • Modified 26 Oct 2013 08:26 by poster
Terberg YT222
SMV (Konecranes) 4632CC5
Sue Tomic Sue Tomic
