Troubleshooting codes
I'm looking for a maintenance Manual for the Piggybacks PB 55 series, in Kubota and Kohler engines. I have code PO222 flashing and my lift is in limp mode, any suggestions or support?
  • Posted 12 Aug 2018 00:12
  • By andre_t
  • joined 12 Aug'18 - 1 message
Andre Tomlin in Christ
PO222 is a throttle pedal code. Check the connection. If any water got into the plug it may have caused some corrosion. Typically if you clean the connector with CFC Free/ Electrical connector cleaner, apply dielectric grease and reconnect, the problem resolves
  • Posted 1 Sep 2018 00:41
  • By HiabT
  • joined 1 Sep'18 - 1 message
