trouble code
I have a hyster 2016 p177v05606p code 679-7 do not know what this code is. Thanks
  • Posted 27 Jun 2018 05:32
  • By sicswagga
  • joined 17 Mar'17 - 11 messages
1347-7 Suction Control Valve (SCV) Stuck
633-7 Pressure Limiter Opening Abnormal
  • Posted 29 Jun 2018 00:20
  • By BREWSKI
I got a call to check the forklift out it is a 2016 h70ft they said it runs and cut off and had the faults 679-7. I told them to put fuel in it. They put fuel in it and it runs but 2 other codes pop up 633-7 and 1347-7. No manual that tells me the codes for this Kubota engine.
  • Posted 28 Jun 2018 05:37
  • By sicswagga
DTC 679-7 - Pressure Limiting Valve Not Opening
A. RAIL PRESSURE FAULT
B. FUEL SYSTEM FAULT
C. FUEL RAIL PRESSURE SENSOR FAULT
D. SUPPLY PUMP FAULT
E. FUEL RAIL FAULT
F. FUNCTIONAL FAILURE IN CONTROLLER
  • Posted 27 Jun 2018 06:30
  • Modified 27 Jun 2018 06:30 by poster
  • By BREWSKI
Briefs United States
