trobleshooting for rre 160
brandnew bt rre 160 not working, the display is blank
  • Posted 23 Apr 2013 03:13
  • By vecky_t
  • joined 23 Apr'13 - 18 messages
  • jakarta, Indonesia
you are right my friend,after i download ,and use version 012 then copy truck configuration from mcu to CID ,the truck back to alive again
  • Posted 23 Apr 2013 23:18
  • By vecky_t
From the screenshot I've viewed your, CID, ACH, ACT don't have any software installed.
Have you tried downloading the software package to the truck?
Make sure you pick version 012!
If the truck has LID option also update it as same time.
  • Posted 23 Apr 2013 17:49
  • By Forkingabout
  • england, United Kingdom
everything is not working,i''d check fuse box ,every fuse is ok,then i use truckcom,i ' ll send you a result snapshot from truckcom to your email
  • Posted 23 Apr 2013 15:05
  • By vecky_t
hard work
If it brand-new it will still be under manufacturers warranty, so not your problem.
Do you have a BT can key? Stick it in & press the green button on the CID, does she start up?
Will it start up in limp home mode?
I button, green CID button, log on to truck as normal.
Be warned if the BT can key is used in limp home mode the seat & deadman pedal safety switches are both bypassed!
  • Posted 23 Apr 2013 12:17
  • By Forkingabout
Kelly Stewart Kelly Stewart
vice president of human resources, Big Joe Forklifts
Board of Directors, UKMHA
at-large director, AED
COO, Intelligrated, Trew and Transnorm
Terberg RT223
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
The dot above a lowercase "i" or "j" is called a tittle.
VETTER Forks, Inc.
