Travel cutting out
The travel will cut out intermittently. I can make it happen 90% of the time. It's almost always does it when high speed kicks in, then the contacts drop out. Travel is disabled until the key switch is cycled. There is nowhere to plug in my handset to pull a code and diagnose. Where do I go from here? I found rec 1 good with handyman. Also tested rec 2 and 5, and those recs did not gate on with the handyman. Can those cause this? I'm just not sure where to go with no code to follow.
  • Posted 28 Aug 2013 08:13
  • By Othell
  • joined 15 Jun'13 - 5 messages
It says ev-100 on the choke. Not sure how to tell beyond that.
  • Posted 28 Aug 2013 20:53
  • By Othell
Is this a EV-1 or EV-100 ? If EV-1, the troubleshooting chart says defective 1A driver, low resistance in 1A filter, or shorted 1A coil.
  • Posted 28 Aug 2013 20:14
VETTER Industrie GmbH
Michel Denis Michel Denis
