Transmission Solenoid?
Hello,
I have a T40C/ SN 38Y04003. Sometimes when I am using it it acts as though I am driving with the brakes on. It will then start driving fine in reverse, but when I shift to neutral it is still in reverse. My thoughts are that somehow the reverse solenoid is hanging and when I go into forward it is still somehow hung in reverse too so I am trying to drive forward while it is trying to go backward. Is this possible?
  • Posted 31 Jul 2017 02:50
  • By CatT40C
  • joined 31 Jul'17 - 1 message
Any accessories installed on this truck such as backup alarm, reverse light, tail lights. etc.?? check voltage at reverse solenoid wire in all direction switch positions, obviously should only have voltage when in reverse. Had a truck once doing similar things because a bad tail light was back feeding from brake light bulb to the back up light bulb causing reverse solenoid to engage when operator used inching or brake pedal.
  • Posted 10 Aug 2017 22:35
  • By Bacon123
  • joined 25 Jul'17 - 10 messages
