Transmission removal
Any info on best way to strip out transmission
regards
  • Posted 17 Jul 2018 01:43
  • By rikki_g
  • joined 6 Aug'12 - 20 messages
  • glam, United Kingdom
Good to hear, also if your lift has a slipping trans there is a quick fix.
contact my profile for more info.
  • Posted 31 Jul 2018 04:16
  • By tom_p
  • Alberta, Canada
Thanks for that Tom
I would have had the engine out without thinking
Looks to be a fault on wiring so hopefully an easy fix compared to tranny repair
  • Posted 20 Jul 2018 17:54
  • By rikki_g
Remove pedals cross shaft, hoses and wire harness. disconnect remove drive shaft, unbolt torque converter flex plate/ring gear through starter hole or inspection hole on top of transmission.
Support engine rear and unbolt bell housing. trans will move forward enough to clear housing dowels and out it comes.
  • Posted 20 Jul 2018 05:40
  • By tom_p
  • Alberta, Canada
Michel Denis Michel Denis
