Transmission No travel
I have a & series that has no reverse or forward drive. checked pressure and have 150 psi on the M port and 0 on the C port which I'm assuming its the Clutch pressure port?
checked voltage at the single solenoid wires on the transmission and I'm getting around.2 volts in forward and reverse
any ideas to check on this.
thank you
  • Posted 24 Mar 2022 02:33
  • By Dino_Tapia
  • joined 18 Nov'20 - 8 messages
  • Missouri, United States
Dino
this truck has a throttle cable so real basic truck.
I believe I have located the issue to the gear selector stock.
  • Posted 6 Apr 2022 01:23
  • By Dino_Tapia
Dino
I found a round relay that was corroded its a 4pin relay on the left side of the truck in the step.
I tested the switch stock and it's working fine according to the test.
Manually powered the forward and reverse switch and nothing so its not seen all the correct settings for this to work.
  • Posted 5 Apr 2022 01:39
  • By Dino_Tapia
Dino
Sometimes the wire for the safetyswitch brakes on the left side of chassis
  • Posted 30 Mar 2022 06:03
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
Ok,i would check the voltage feeding the relays inside the fuse box( in some models they are located in left side under the floor plate).
2 volts its not enough to activate the solenoids. You can have a leak to ground too.Check the wires carefully.
  • Posted 29 Mar 2022 10:32
  • By feitor
  • joined 6 Jan'11 - 161 messages
  • Leiria, Portugal
my email: rc.feitor@hotmail.com
No it's the the sensor only.
  • Posted 29 Mar 2022 08:22
  • By Dino_Tapia
Dino
Does it have the safety switch on the acelerator pedal?
  • Posted 29 Mar 2022 07:36
  • By feitor
  • Leiria, Portugal
Maxlion R2D35
SMV (Konecranes) 12-1200B
