Transmission fault on a TCM FHG18T3
Hello,
I have a transmission fault on a TCM FHG18T3 where when you engage drive there is about a 3 second delay for drive to engage
I have checked the pressures on this transmission of which i am getting readings of
Charging pump 180psi at tick over and 220psi when the truck is revved up
torque converter 10-15 psi at tick over and 90 psi when revved up
and clutch pack pressure of 100psl once the truck engages drive ( and will drive )
I do not have a workshop manual for this transmission to know what pressures i should have,
So could any one tell me what they should be ?
but given the pressure on the torque converter is only 10-15psi on tick over i am now inclined to think that the fault (the delay on drive ) is due to a faulty converter, Whats your thoughts ?
Regards
John
  • Posted 11 Jul 2019 03:35
  • By JohnBon
  • joined 25 Mar'16 - 11 messages
  • Staffordshire, United Kingdom
Hello John,
I have Service Manual for TCM FHG 18T3 ( Book Version).
Please, send me your Mail.
Regards
  • Posted 15 Jul 2019 22:05
  • By stefano_tcm
  • joined 25 Oct'14 - 110 messages
  • ITALIA, Italy
TCM Forklift spare parts
tcmricambi@gmail.com
your readings on the torque converter pressures are within specs for a torque converter pressure range.
What i would be checking is the inching adjustments and making sure it is releasing completely, if inching circuit is not fully releasing it can cause a hesitation in the clutches engaging.
Other things to check would be the inching spool/linkage/cable for binding.
Otherwise there may be some issues with the flex rings or something else in the clutch packs. (this would be worse case scenario)
  • Posted 11 Jul 2019 15:26
UN Forklift FL20-32LNJX2
Maxlion R2D25
