Traction Controller Bad???
Wondering if anyone has any further thoughts on this? When you turn the key on the display says "TURN KEY OFF". None of the contactors pull in. I have bypassed the Line, steering, and hydraulic contactors. After this was done the steering motor and hydraulic motor will run but there won't be any functions. Checked the seat switch, park brake switch, and confirmed that there was continuity from the key switch to controller. Any thoughts? Thanks.
  • Posted 18 Aug 2012 08:24
  • By ATK1
  • joined 27 Jan'12 - 74 messages
  • South Dakota, United States
allenk@ntlifts.com
yea, I said it poorly, I am going to blame it on English not being my 'first tongue',
My 'first tongue' is "yoda", with English, besucher German and poquito Spanish all thrown in.
As a graduate of Miami Dade county public schools, I can claim to be functionally illiterate in 2 languages. I am still working on it (obviously).
that's my story and I am sticking to it.
  • Posted 1 Sep 2012 23:38
  • Modified 1 Sep 2012 23:38 by poster
Oh,ok gottca...understand what your saying.
  • Posted 1 Sep 2012 21:54
  • By kevin_t
my only point there was if some meatball (like me, since it is how I learned it, many years ago) put the input wires in the wrong screw terminal on the truck management module, which from that point, until it was corrected, would send the improper code to the dash.
  • Posted 1 Sep 2012 21:52
Ed: I looked up the code descriptions "ONLINE" for this truck and these descritions are for these codes and truck model....
  • Posted 1 Sep 2012 07:19
  • By kevin_t
Hey Kevin, while that might be correct 90%, any code above 89 is for "manufacturer codes" (Truck management module inputs to the logic) and these codes can relate to whatever the manufacturer's engineers or techs have chosen, they are outputs that the manufacturer decides the order of, so it might be motor temp, or brush wear indicators, and what sensor is for what code may have as much to do with the order someone put wires back on to a truck management module, than what the book says they go to. I know in my life I have spent days wondering why I get a motor over temp code when it turned out the problem was the brushes were worn out.
  • Posted 1 Sep 2012 06:51
If this truck has the GE EV100ZX Control system code 90 is For traction motor Temperature to high.
Code 93 is steering motor brushes worn and need replaced
  • Posted 31 Aug 2012 10:43
  • By kevin_t
Are there any battery retaining bar switch's on this truck if so i would check them. Do you have the serial # of the truck to post?
  • Posted 31 Aug 2012 10:32
  • Modified 31 Aug 2012 10:34 by poster
  • By kevin_t
seat swich not closed. head contaktor dont close
  • Posted 31 Aug 2012 04:06
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
So we did replace the main GE computer board/traction controller. We now get codes 90 and 93 to pop up. We also still get "TURN KEY OFF" on the display. Any help is appreciated. Thanks.
  • Posted 25 Aug 2012 10:01
  • By ATK1
allenk@ntlifts.com
Crown RD572513TT6860R
Linde C4230TL5
