Traction Contol Cuts Out When Unit Heats Up
I am having an issue with the control system on this truck. (Cableform) 48V
The truck shuts down after it heats up. The system will start again after just a few minutes and it doesn't give me enough time to troubleshoot the problem. I have taken the temperature sensor out of the equation by jumpering the ends together. The truck continues to cut out and I am looking for any sugestions.
  • Posted 5 Mar 2008 09:36
  • By Brian
  • joined 5 Mar'08 - 1 message
Its your ptc on the right side.
Its yellow color
Put A resistor of 150 ohm in that line
You solved the problem.
Regards.
John.
Netherlands
Clark
  • Posted 12 May 2008 04:17
  • By johngen
  • NB, Netherlands
Check the drive motors,power cables,and contact tip. If any of them show signs of overheating,or the drive motor comontators and/or field windings for shorts or burnt-up, then replace them. Next would be to check out individual components on the SCR panel,using a handyman tester.Also test the thermal protector,for to high or low resistance.
  • Posted 31 Mar 2008 04:12
  • By Truck_Tech
  • United States
