Toyota forklift restoration - info needed
Hello everyone. I've found this web site looking for information about old Toyota forklift I just bought and I'm trying to restore. I'm trying to find out any information about this forklift, including when this forklift was manufactured. On the front side of the forklift there are two plates, first containing this numbers:
62-2FG25
60-2FG25-10035
8740 LBS
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0327_zpse9fad7c6.jpg
and the second one containing this information:
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0326_zps93dc0f11.jpg
On the right side of the forklift on the frame where the hood meets, along the edge there also number, same as the one on the plate:
60-2FG25-10035
On the engine hood on the right side there is this plate:
i1330.photobucket.com/albums/w578/juricaz/toyota/ba35cf0c-1e08-45e9-a3f0-39107ed6ba17_zps762baa40.jpg
i1330.photobucket.com/albums/w578/juricaz/toyota/b0912d89-3cd8-4de8-a85c-94d78e366102_zps08a2dbc6.jpg
I'm also trying to find out any information about distributor block/controle valve, how to repair it, where to buy another one, because mine is broken. I think this is also called 3 Spool Hydraulic Valve. Here are the pictures of mine:
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0340_zpsd54afd6f.jpg
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0341_zps130eee7a.jpg
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0344_zpsbf1dbb15.jpg
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0345_zps5b7aea55.jpg
Another thing I'm trying to find more information about is LPG system on my forklift. It's IMPCO system consisted of VFF30 vacuum fuel lock/filter with two stage converter model J and carburetor CA 50. I don't know if I'm missing some part of LPG system.
On the engine, there is a number: 5P-0002149
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0334_zpsbcd344ea.jpg
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0332_zps782425e3.jpg
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0333_zps85753dfb.jpg
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0335_zps95db0f22.jpg
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0336_zps79d70eea.jpg
i1330.photobucket.com/albums/w578/juricaz/toyota/IMG_0337_zps6cec905a.jpg
  • Posted 13 May 2013 06:12
  • By jurica_z
  • joined 13 May'13 - 2 messages
  • Virovitica-podravina, Croatia
I don't have anything in Toyota manuals that goes back that far.
The oldest manual I have covers the 3FGCU models. The print date for that book states it is an updated publication covering all 3F models from 1974 (and later).
Knowing that Toyota often has continuing production of a prior model even after a succeeding model has already begun production and marketing just makes it harder to pinpoint a range of model years.
My guess on the actual age of a 2F would be from the early 1970s to the late 1970s.
As has been stated, a good Toyota dealer might be able to tie a build date to the serial number. It's old!
  • Posted 14 May 2013 08:34
  • Modified 14 May 2013 11:11 by poster
  • By L1ftmech
  • Tennessee, United States
There should be a fitting on the fuel line between the tank and the Model J called a bulkhead. That is where the hose goes from the outside of the lift through to the engine compartment. That has a little metal filter in it. The VFF30 has a large filter in it, under the one cover.
  • Posted 14 May 2013 05:48
Thanks mrfixit. This is great news. Do you know if I need any kind of filters for LPG installation?
  • Posted 14 May 2013 05:37
  • By jurica_z
You pretty much have all the info from the ID plates
model 62-2FG25
serial 10035
motor Toyota 5P
Those are the 3 parts for a common Impco fuel system. The only thing missing are the hoses.
Depending on what is wrong with the hydraulic valve, it might be repairable. The seal kit is Toyota # 04671-20340-71. A hydraulic repair shop can do that.
A Toyota dealer or someone who specializes in forklifts should be able to get any parts you need. The dealer can let you know the model year by the serial number. It's old.
  • Posted 14 May 2013 05:11
  • Modified 14 May 2013 05:24 by poster
Combilift Ltd
