Toyota 7FGCU25
have a 7 series Toyota that is not producing enough vacuum to start engine unless add a slight restriction to air intake and engine will start and produces 15 psi of vacuum will idling, has 140 compressions across all cylinders performed leak down test on all cylinders all passed runs normal once get engine started and functions properly looking for cause of no start unless restrict air intake on carburetor, all parts of fuel system are new and to include governor and throttle body
  • Posted 17 Oct 2025 05:24
  • By jeffrey_crumrine
  • joined 17 Oct'25 - 1 message
  • kansas, United States
jeff crumrine
Check to make sure carb, intake gaskets are not blown out, hard. There's been some issues with improper placement of gaskets. The heat riser gasket needs below the drip pan. Or 1 st gasket on the intake. It's 1/8" thick. Then the pan, governor etc.
check your flexible vaporizer hose at the vaporizer outlet. They rot from the tar sitting on them and soften up and leak. Causing hard starts and or no start.
Also slow path solenoid fills up with tar if the vaporizer hasn't been serviced properly.
  • Posted 17 Oct 2025 09:56
  • By ron_k
  • joined 2 Apr'15 - 146 messages
  • North Dakota, United States
4kliftman
October 12-15, 2026 - Detroit, MI, United States
October 22, 2026 - Sydney, Australia
January 26-27, 2027 - Balikpapan, Indonesia
edition #1299 - 17 September 2026
With the world changing, in seemingly too many ways to fully comprehend, businesses need to be agile enough to change with it... Continue reading
The dot above a lowercase "i" or "j" is called a tittle.
Zhejiang UN Forklift Co., Ltd
Kelly Stewart Kelly Stewart
vice president of human resources, Big Joe Forklifts
Board of Directors, UKMHA
at-large director, AED
COO, Intelligrated, Trew and Transnorm
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
