Tilting Function inoperable
Tilting Function is not operating. Mast raises and falls normally. Side shift works properly as well. Batteries are fully charged. The lift runs forward and reverse normally. Trying to diagnosis with no luck.
  • Posted 15 Feb 2019 06:12
  • By racetireman
  • joined 15 Feb'19 - 4 messages
  • Michigan, United States
Adjusting the switch fixed my tilting issue.
Thanks Much for all your assistance Mr. Fixit!
  • Posted 19 Feb 2019 05:55
  • By racetireman
Thank You Mr. Fixit. I will work on that repositioning and let you know how that works. In the mean time, Thanks Much for assistance.
  • Posted 19 Feb 2019 00:45
  • By racetireman
It probably needs to be adjusted (positioned correctly) so the pump shuts off when the lever is not being used.
  • Posted 16 Feb 2019 09:42
I found a broken wire on the switch to the tilt lever. Repaired that break and tilt work again. However, now the pump constantly runs which is not how it functioned previously. Could the switch be faulty now? Or could it be positioned incorrectly now? Or does the pump need to run for a while to purge any air out of the system? Thanks for the quick reply!
  • Posted 16 Feb 2019 07:33
  • By racetireman
Did you check the switch on the hydraulic control valve that turns on the pump when the tilt lever is used?
  • Posted 15 Feb 2019 23:08
Stu Jacover Stu Jacover
Chief executive officer, TVH
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
