chasing my tail
I. keep getting different problems with this thing. They seem to keep changing. Last thing was everything worked except up and down mast. when I pushed in the relay contacts, it would work. I replaced that whole part with a new one thinking the relay portion _bad. Same problem but now the extend stopped working. I cleaned all the connectors on the boards with contact cleaner. Same. Help please.
Thank you in advance.
  • Posted 8 Oct 2016 06:46
  • By gregk
  • joined 10 Nov'15 - 15 messages
doubt anything wrong with learns. would be coding 80 81 or 83 with lift request.
  • Posted 7 Feb 2018 09:17
  • By stam
Thank you Stam. I got so busy used a Crown sit down. Problem is doesn't turn enough to be helpful inn close areas. So I'm back on Fixing the Raymond. Thabk you for al the ideas. Is it possible in is something in the learning mode? I have the first password but not the superpassword I will keep you informed.
  • Posted 7 Feb 2018 05:53
  • By gregk
For the no reach, if tilt and sideshift both work check the overmast cable for breaks, check the wires are on the reach select solenoid behind the top of the carriage. If nothing out there works check mast cable again, also there is a line filter under the top cover close to the handle it has a blue capacitor sticking up and a 1/4 turn fuse holder, check the fuse in there, if ok probaly cd5.
For the no lift, that is strange. Typically with the truck keyed on if you manually push the contactors in the truck will code 40 something. Is there extra mast switches fitted? When raised will it lower? If not check the lift lower pot make sure it's turning the pot shaft, check the pot itself.
  • Posted 10 Oct 2016 06:07
  • By stam
No codes. 72% on the battery. The aux pump does come on.
  • Posted 9 Oct 2016 15:34
  • By gregk
Any codes displayed? What does the odi say the battery % is?
When requesting reach while off the deadman pedal do you hear the aux motor come on?
  • Posted 8 Oct 2016 07:40
  • By stam
