PSI 2.4 engine oil consumption
Hey all, new guy here, but I've picked up some great tips from the forums, so thanks for that!
My question is about some newer trucks with the PSI 2.4l LP engine. I've been working on a few tricks with this engine and they are losing about a quart and a half of engine oil a week. Anyone else seeing issues with this? No leaks, no oil on the coolant. Trucks now have about 1800 hours on them and have been consuming oil since new.
  • Posted 8 Sep 2016 20:36
  • By YaleDropout
  • joined 8 Sep'16 - 2 messages
  • Virginia, United States
Put a 0-15 # gauge in the 1/8 pipe plug port on the vaporizer. Should maintain 2-4# with the truck running.
  • Posted 13 Dec 2017 09:22
  • By BREWSKI
Dont believe im loosing spark but no fault codes. What should i check within lpg system
  • Posted 13 Dec 2017 05:10
  • By rashaun_m
  • joined 21 Nov'17 - 7 messages
  • Illinois, United States
Rm
Are you loosing spark? You may have a fuel system problem if you are not loosing spark. You should be getting a fault code if the truck shuts off while running.
  • Posted 13 Dec 2017 04:10
  • By BREWSKI
Hey guys i have a H50ft psi 2.4 im having crank no start changed plugs got spark on all cyl. Will intermittently start but will shut off. Maybe crankshaft sensor or camshaft sensor any and all help greatly appreciated
  • Posted 13 Dec 2017 01:27
  • By rashaun_m
Rm
I work for Yales brother..I have 8 PSI trucks in a 24/7 operation that is hot and dirty. Have seen many coolant tube issues and also water pumps ' Trucks are 1.5 years old and some are near the 8000 hour mark. I have not seen any oil use in any. Have seen oil leaks at filter fittings but no big usage as you describe. Only other issue on all units was fault code running rich. Tried a few things but did not resolve issue. Opened up mixer and found propane oil and dirt build up on the bulb of the diaphragm. Cleaned off, put back together and all running fine again. Diaphragm was heavy and not moving properly. Saves wasting customer money on new mixer.
  • Posted 14 Oct 2016 11:43
  • By geoff_g
  • joined 23 Jan'15 - 12 messages
I'm a field tech for the local dealer. I've made some folks aware of what I've been seeing and they are looking into it. I was just curious to see if anyone else had noticed issues with these engines, the only other problems I've had are the o rings on the water pipe that runs from the thermostat housing to the fuel system.
  • Posted 9 Sep 2016 09:53
  • By YaleDropout
We have quite a few of these. We have not seen any oil consumption issues yet. Will check with other field techs and let you know. Have you contacted the dealer?
  • Posted 8 Sep 2016 22:23
  • By BREWSKI
Sue Tomic Sue Tomic
Noblelift
