Wiring diagram for duel fuel engine
I have a shorted wiring harness. Is there a wiring diagram available with the wiring colors? I have an email in my profile.
Thanks
  • Posted 24 Aug 2016 03:39
  • By Isometriks
  • joined 3 Apr'16 - 4 messages
  • Alabama, United States
The only way to fail is to not do anything.
i guess a standard P5000 diagram might get you by for basic circuits but they did make quite a few changes in these trucks over the span since they were introduced. Plus there are 3 different wire harnesses for these trucks depending on which model and the options it had when it was made. Usually a standard wire diagram will cover most of it but....
with that being said you will probably want a more accurate diagram and having a FULL truck serial number will get you the exact diagram for that truck in most cases and there wont be as much guess work involved when checking and reconnecting circuits and identifying wire colors or numbers.
  • Posted 24 Aug 2016 08:27
  • Modified 24 Aug 2016 08:28 by poster
I e mailed a diagram of that circuit
  • Posted 24 Aug 2016 04:12
Zhejiang UN Forklift Co., Ltd
