Fault 2A
Intermittent code 2A along with temperature indicator. Turns on and disables lift for 5-10 seconds then starts and all is ok for many hours or days.
Is this fault for drive motor temp?
  • Posted 19 Aug 2016 02:22
  • By tom_p
  • Alberta, Canada
Yes it is for Traction motor approaching over temp. sounds like you may have an intermittent open in the temp sensor wiring
Run Test A08 if you can access the system
  • Posted 19 Aug 2016 03:50
  • By Rbarn
  • joined 18 Aug'16 - 5 messages
Enforcer FD50T-MMA
Mitsubishi FGE35AT
ROYPOW
ROYPOW
Sue Tomic Sue Tomic
