mini-levers
Just took over this account. Their Yale is showing a hydraulics lock-out message on the screen. Have no information on this truck at all. I suspect that the potentiometers in the mini-levers need to be matched similarly to the Toyotas I am more familiar with, but I don't know how to get into the dash to do the matching. Any help would be appreciated.
  • Posted 1 Mar 2016 01:12
  • By ramon_m
  • joined 30 May'14 - 42 messages
Perseverence is a virtue.
I replaced the lever assembly and all is good. There appears to be no matching function on this truck for the controller to learn a new centered resistance value. The only thing to do is replace the lever assembly.
Thanks
  • Posted 3 Jun 2016 00:43
  • By ramon_m
I'm having the same problem: Hydraulic interlock - Return to neutral. Switch seems good and mini levers are at 0%. I may be missing something. Could use some advice asap. Thanks in advance.
  • Posted 2 Jun 2016 23:38
  • By Rob11
  • joined 2 Jun'16 - 3 messages
You need the Service level password or the supervisor level password to access the calibration mode. If the code comes up as soon as you turn on the switch, calibration will not help. One of the mini levers has lost center and needs to be replaced. First off you need to check the seat switch to make sure it is closing. The hydraulic interlock will display if the switch is open.
  • Posted 1 Mar 2016 04:07
  • By BREWSKI
Maxlion ESD15M
Terberg YT220
Maxlion ESD15M
Terberg YT220
