electrical
our lift won't stay running, it has burnt out the main module for the 3rd time , we bought it used. I believe the company we bought out from converted it to LP. We have replaced evrythingthethe converter, carb,the vacuum, the regulator and even some of the wiring, re[placed all filters,. we have had it running reallygood for only about 3 days, and it has again blown the main electric modular,. The guy at the place I have been buying my parts has helped a lot , but he only knows the gas parts or lp and converter. Can someone help we got a lemon....not knowing because it ran when it was delivered but all the safety wks and parts had either been taken off or bypassed we fixed all that too. We are at our wits end. Any Ideas and Thank you.
  • Posted 27 Feb 2016 06:42
  • Modified 27 Feb 2016 06:44 by poster
  • By robin_g
  • joined 20 Feb'16 - 10 messages
I would replace the ignition spark coil and resistor also. It may have a problem causing it to draw too much power and overloading the module (ignitor) causing it to fail.
  • Posted 19 Mar 2016 03:50
this is a F25 lift, it was upgraded(?) to a log from gas.
the part that keeps blowing is the electronic modular that is part of the distributor. thank you
  • Posted 19 Mar 2016 03:00
  • By robin_g
the part that keeps blowing is the electrical modular that is part of the disturber.
thank you
  • Posted 4 Mar 2016 09:48
  • By robin_g
thank you for responding let me check and see if they will tell me I have to get and I will also get the model and see#, I know it is a Mitsubishi F25
  • Posted 3 Mar 2016 06:32
  • By robin_g
I am confused what are you refering to when you say main module?....ignition control module???...and what is the make,model and serial number of the truck in question?
  • Posted 27 Feb 2016 12:31
  • Modified 27 Feb 2016 12:33 by poster
  • By kevin_t
Michel Denis Michel Denis
