Hydraulic return line?
We seem to have a persistent leak of what appears to be the return line coming back from the control levers back to what I believe is the bottom of the reservoir. There appears to be a component inline (filter?) Anyway to change this hose, the clamps, and filter? What is the best way? Does all the fluid need to be drained? How much fluid? Is there a trick to replacing this hose? Thanks
  • Posted 10 Feb 2016 06:36
  • By KBlackPronto
  • joined 10 Feb'16 - 4 messages
  • Oregon, United States
return filter. check the position of the hosing to the tilt cylinder. these can cause the filter to flex and crack.
  • Posted 10 Feb 2016 17:30
  • By kevin_k
So that widget in the return line is also a filter?
  • Posted 10 Feb 2016 15:22
  • By KBlackPronto
No trick to it. If the hose is in the bottom of the tank you need to drain the tank. Capacity is about 10 gallons. I would not drain and refill the tank without changing the filter also.
  • Posted 10 Feb 2016 07:25
  • By BREWSKI
Sue Tomic Sue Tomic
Toyota 02-2TD20
UN Forklift FD35T-C2JB2
Sue Tomic Sue Tomic
