Breaks
Need some one to explain to me if I should see the top cap of the master cylinder for the breaks (held in place by a retaining ring) move slightly inward when the break pedal is pushed. When applying the breaks it moves in a little and will leak trans fluid. It wil also leak even with the unit shut off.
Hyster Model S80FTBCS
  • Posted 4 Jul 2015 01:57
  • Modified 4 Jul 2015 01:59 by poster
  • By Vdog
  • joined 2 Jul'15 - 3 messages
  • Michigan, United States
What you re seeing is the top of the brake booster unit. The master cylinder is mounted under the booster unit.
  • Posted 18 Jul 2015 06:15
  • By BREWSKI
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
