E25-01 91X336L01866 FAN ALARM
A customer has asked for assistance with a yellow alarm light on this trucks dash read out.
Model has a circular dial display with 4 yellow warning light segments, 2nd from left has a fan symbol this is on from power up and does not go out.
Any idea if this light refers to traction motor temp or hydraulics or both.
we have very little experience with this model local dealer doe not want to know machine.
any help appreciated.
Steve NZ
  • Posted 18 Jun 2015 13:59
  • By stephen_f
  • joined 18 Jun'15 - 2 messages
  • Christchurch, New Zealand
https://www.aliexpress.com/item/1005001268095719.html?spm=a2g0o.productlist.0.0.6ab627b5lAnmDT&algo_pvid=182f8622-6f0b-49b6-a9c7-3c3ad3cb5804&algo_expid=182f8622-6f0b-49b6-a9c7-3c3ad3cb5804-0&btsid=0bb0622a16044247726887101ebe81&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
6
  • Posted 24 Nov 2020 01:41
  • By JonoG
  • joined 15 Feb'19 - 77 messages
  • Uruguay
Jonathan Gill
Sorry Jono,that should have been 1100.00 dollars.
  • Posted 24 Nov 2020 01:35
  • By Alberta
  • joined 3 Feb'17 - 30 messages
  • Alberta, Canada
truckshop@lonepinecolony.com
Where can I get a combined instrument for 11 dolars ?
  • Posted 24 Nov 2020 01:22
  • By JonoG
  • Uruguay
Jonathan Gill
  • By JonoG
  • Uruguay
Jonathan Gill
There are 3 temp sensors on these machines, check the resistance on these sensors first the information is in the service manual, if that tests good then check the continuity for the wires up your composit instrument quite easy to do, on our machine that all tested good and it turned out to be the composit instrument itself 1100.00 dollars Canadian dollars, our machine also was in limp mode with the fan on all the time but you should get the codes first.
  • Posted 12 Sep 2018 23:40
  • Modified 24 Nov 2020 01:36 by poster
  • By Alberta
  • Alberta, Canada
Hi can i ask also. What is error code t220 pls need some idea
  • Posted 12 Sep 2018 01:58
  • By chadaw_isidro
  • joined 12 Sep'18 - 21 messages
  • Saudi Arabia
It simply means - "check the fan"
There are two of them on the font axle of 336-01
Check, if they work, the connections and plugs.
Should be simple.
  • Posted 26 Jun 2015 00:41
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
Maxlion FDR45
SMV (Konecranes) 33-1200C
Michel Denis Michel Denis
Maxlion FDR45
