Without hydraulic functions and traction problems
Hello Guys, I am here because for your help.
I have a Raymond Easi Double Reach, EASI DR30TT-B model with EZ-C-05-32557 Serial and i have some problems with this forklift.
Now show the 6x fault code and don't works any hydraulic functions and when i try move the forklift to ahead or reverse, it moves sharply in reverse in the majority of the cases. When I move gently the joystick in forward position, in some cases, it goes gently to forward.
Some times it shows the code 83 and 84 with the key for service.
Do you know what is the meaning of this codes? What is your recommendation?
I think that there is a problem with the traction potentiometer calibration due for the traction problem and in some times the display shows "reset joystick to neutral position" or something like that.
I was revising and i found a short circuit with some lines of control cable, i separate the wires, and put tape.
I looked the AC controllers, the first led of hydraulic controller is blinking all time. The first led of the traction controller is on all time.
I appreciate your help
  • Posted 28 May 2015 10:48
  • By Yangomez
  • joined 28 May'15 - 10 messages
  • Bogota, Colombia
Hello Ray, thanks for your fast answer, I dont have the password and superword, i will try to use your suggestions. How i can get into on Learn Mode? is it a combination of handle buttons? Thanks
  • Posted 28 May 2015 23:15
  • By Yangomez
  • Bogota, Colombia
Yes, it's the pot in the handle. First of all, do you have the pass word to get into learn mode? Try default 1 for password, 2 for superword.
Need superword for learn, diagnostics. Without superword, you cant even install a rebuilt handle because its needs calibration to work.
Before doing anything, make sure the set screw that locks the handle is tight. If it backs off,the handle will be out of adjustment. Check this, and do you have the superword?
  • Posted 28 May 2015 13:16
  • By EasiTek
Taylor TT300
Nagano NUL120-6
edition #1257 - 20 November 2025
Bolzoni SpA (Group HQ)
