Rebuilt Engine Can't Get It Started
We just had a engine rebuilt for a H30D. It is a VW CBHA engine for a H30D. If we spray diesel starter fluid into the air intake the engine starts for about 5 seconds. We have fuel from the filter to the vacuum pump. But not sure from there? Anyway to test the injectors? Any Suggestions would be welcomed!!!
  • Posted 11 Dec 2014 08:49
  • By Howard
  • joined 22 May'14 - 5 messages
  • New Hampshire, United States
Hook up laptop and go to motor Diagnostic and check the basic timing degree. I set mine about 50, a range of 25 to 70. injection pump timing could be off. I have had readings as hige as 102 and as low as 15
  • Posted 11 May 2015 13:07
  • By edward_m
  • joined 11 May'15 - 111 messages
I found the easiest way to bleed the system was to remove the return banjo fitting from the injector pump and connect a hand pump to pull the diesel through as there is no primer pump for these engines. Saves a lot of excess engine cranking!
  • Posted 15 Dec 2014 20:04
  • By little_forker
  • joined 31 Jul'11 - 82 messages
you prime the injector pump and bleed out the injector lines before trying to start?
bleeding the air out of the system is a must or it just wont start up due to air lock in the lines.
  • Posted 12 Dec 2014 13:35
this truck also has a p3008 code iv found out and the glow plug light flashing
  • Posted 12 Dec 2014 06:34
  • By klan595
  • joined 12 Dec'14 - 1 message
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
UN Forklift FBRS15KQZ2
SMV (Konecranes) 4632CC5
Jim Tompkins Jim Tompkins
Sales operations, Heli
