Still EXU 20 Error Code
Hello still expert
My truck Still EXU 20 won't move and the lift not function
I found error E1 238, E2 234 and I don't know what the meaning
is there anyone can help me with the error code.
Regards
  • Posted 10 Nov 2014 21:15
  • Modified 10 Nov 2014 21:16 by poster
  • By Tango
  • joined 10 Nov'14 - 2 messages
  • Bekasi, Indonesia
dwi.hartanto76@yahoo.co.id
can some please find out error codes for STILL EXV 12
E1 238
E2 235
E3 234
E4 408
  • Posted 6 Feb 2021 07:50
  • By Saeed_Khan
  • joined 6 Feb'21 - 4 messages
  • Pakistan
saeedkahn
yes this is diesel lifter. this problem has started when the switch on gas pedal stop working and I changed it with oder but it was not wright and then it was some strange noise from lifter. then I got the correct switch and since then this problems continued, before it was all ok. thank you for all info.
  • Posted 28 Nov 2018 00:29
  • Modified 28 Nov 2018 00:30 by poster
  • By zivko_o
  • joined 26 Nov'18 - 7 messages
  • Slovenia
R70-30 model is diesel lifter if this is diesel lifter so slonide coil installed on the top of gear box behind brake and exceleretor pedal. Solonide coil used for drection forwerd or reverse.
  • Posted 27 Nov 2018 23:08
  • By muhammadsajid_j
  • joined 23 Nov'18 - 12 messages
  • Sindh, Pakistan
Sajid jutt
what is the slonide coil and where do i find it on forklift
  • Posted 27 Nov 2018 21:39
  • By zivko_o
  • Slovenia
Did you check its controll card if done then you should have to check direction switch and slonide coil.
  • Posted 27 Nov 2018 18:47
  • Sindh, Pakistan
Sajid jutt
hello I have a R70-30 still manufactured in 2001. it indicates error code 2, 57, 58, 195. if I'm working with it for more than half an hour the error 195 is displayed and the forklift drive is switched off and does not go no forward or reverse until it cools down. I think that something is overheated then the error 195 is displayed, what is the problem?
  • Posted 26 Nov 2018 02:53
  • By zivko_o
  • Slovenia
Hi,
I am working on still stacker model Exv12 one problem creat problem for me Error E1 238 durring running stacker stop then reset it again running
Checked Brake ok
Checked temp sensor ok
Check ckecked all cables ok
I think potentimeter faulty but with out installation of Potentiometer this error comes Why?
  • Posted 23 Nov 2018 20:49
  • Sindh, Pakistan
Sajid jutt
Hi Nuna, Thanks a lot for reply.
I'll try it soon.
I'll get back to you with a good result, hopefully.
  • Posted 25 Nov 2014 21:48
  • By Tango
  • Bekasi, Indonesia
Hi
This means the tiller potentiometer is faulty. Just replace the new one then it must be OK
  • Posted 15 Nov 2014 01:02
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
