No hydraulics
No lift-tilt-side shift and stiff steering. Any ideas?
Haven't checked pressures, fluid level is ok
  • Posted 6 Oct 2014 01:03
  • By shaun_p
  • joined 14 Dec'12 - 15 messages
Thanks swoop.. I will post back with my findings
  • Posted 6 Oct 2014 09:31
  • By shaun_p
the secondary relief valve (located on the end housing of the control valve) may be damaged.
pressure test port is located on the main lift valve section, hook a 3000psi guage to it and then operate the tilt in a stall mode and take a pressure reading. it should read about 2250psi.
if it does not then you have an issue with the flow regulator (secondary relief valve) for auxillary pressure.
this would be my first guess since it is affecting all the auxillary functions and steering.
  • Posted 6 Oct 2014 07:42
D187V30400A
GM engine
  • Posted 6 Oct 2014 02:04
  • By shaun_p
Serial number of truck??
  • Posted 6 Oct 2014 01:58
  • By kevin_t
Hawker Powersource, Inc.
Michel Denis Michel Denis
