travel contactor
pallet jack will travel f and r ,but as soon as the pump contactor pulls in the line contactor is thrown out and the key has to be cycled for travel again. contactor tips are in good condition.i have the manual for this pallet jack but it is not much help. sem drive motor on this jack. any suggestions would be appreciated.
  • Posted 23 Jun 2014 00:01
  • By deadshort
  • joined 22 Jun'14 - 6 messages
check the hydraulic motor for an earth fault not had the problem on a crown yet but had plenty on jungheinrich's acting like this normaly find an earth fault on the hyd motor remove it strip and clean it out and the truck works fine again
  • Posted 4 Jul 2014 23:57
  • By lifter01
  • joined 4 Jul'09 - 463 messages
i went to the customers location this morning the batteries had grease on the terminals ,lots of grease and there was 22 volts measured across the top of the batteries. after cleaning and flushing the battery compartment the case voltage dropped to.224 volts.the pallet jack seems to run normal at this point.i sincerely appreciate the help. it always pays to use the kiss system first.
  • Posted 24 Jun 2014 03:28
  • By deadshort
I agree, it sounds like a bad battery or voltage drop in a bad connection or fuse.
  • Posted 23 Jun 2014 01:42
i did notice when taking a voltage reading at the pump about 21 volts when activated. the pallet jack is a24 volt system.
  • Posted 23 Jun 2014 00:33
  • By deadshort
First thing is what's the battery condition like?
  • Posted 23 Jun 2014 00:04
  • By Forkingabout
  • england, United Kingdom
Briefs United States
Tusk 500PGH16
Crown CG33P5
