H80D slow tilt
...I'm having an issue with an H80, that doesn't throttle up when tilting or fork positioning. It throttles up when lifting, but doesn't for the other commands. they are very slow....no codes....went thru everything with the laptop today when I plugged into it..everything looks ok. Hydro fluid is up....pump sounds noisy at idle though
  • Posted 30 May 2014 11:58
  • By ctforkliftguy
  • joined 14 Mar'13 - 48 messages
  • Connecticut, United States
Hello.
did you fix this problem?
  • Posted 11 Nov 2015 08:23
  • By sjoold
  • joined 24 Oct'15 - 25 messages
  • Norge, Norway
Kindly check on the hydraulic control valve solenoid valve may be the one opening for the tilt cylinders is faulty. The bleed the hydraulic system.
  • Posted 23 May 2015 00:08
  • By Oloibiri
  • joined 22 May'15 - 5 messages
  • Nairobi, Kenya
Briefs United States
Combilift Ltd
