Hydraulics leaking down
When in use all cylinders leak down. It's a double mast lift and I was wondering if there is a master check valve somewhere in the line thats allowing the cylinders to leak. Even the tilt leaks down. Can't believe they're all leaking internally and not externally.
Share your knowledge please????
Updown
  • Posted 30 May 2014 05:53
  • By Updown
  • joined 30 May'14 - 1 message
  • Maryland, United States
Need some info on a TCM that leaks down constantly
Install a manual shut off in the hoist cyl's feed line. Open the valve- raise the forks 'bout half way- close the valve & wait & see what it does.
If it still leaks down- hoist cyl issue. No leak down - control valve issue.
The tilt cyl's may be another issue- If one tilt cyl packing is faulty it will let the tilts drift.
  • Posted 5 Jun 2014 23:52
  • By bbforks
definatly could be a relief valve problem
could also be a bad spool in main lift section of control valve
also could be packing or safety valve in one of the outer cylinders
since fluid has to go through the outers to get to the freelift cylinder if there is a problem in one of the outer cylinders (usually the first one where fluid enters mast system) it can cause the whole system to drift down.
  • Posted 30 May 2014 20:47
Maybe a leaky / slightly stuck open pressure relief valve in the system.
  • Posted 30 May 2014 06:44
  • By Forkingabout
  • england, United Kingdom
SMV (Konecranes) 4632CC5
Crown RR5225-30TT321
