CODE E118
I know that everyone knows that a code E118 is usually batteries. I had an E118 this morning and I found 2 bad batteries. Changed the batteries and the code was still there. I had 25+ volts on the battery and the controller/contactor. I started moving the main harness on the left of the lift and the code cleared. Does anyone know what wire the 25 volts goes to the main control board in the control handle that sets off the code
Thanks
in advance
  • Posted 18 Mar 2014 22:57
  • By joe_r
  • joined 1 May'13 - 9 messages
Four wires going to control handle
Wire # 22 +24v red at connector going up into handle(red)
Wire # 119 gose to traction amp its CAN HIGH (green )
Wire #120 gose to tracion amp its CAN LOW (white wire at connector)
WIRE# 40 0 VDC ground gose to back of horn (black wire at connector
  • Posted 21 Feb 2017 02:31
  • By mpifer
  • joined 16 Aug'14 - 38 messages
E107 most often means your Main Contactor is stuck! Tap it with a small hammer in the off position and retry...
  • Posted 14 Feb 2017 23:10
  • By darrell_s
  • joined 14 Feb'17 - 2 messages
cant find a c107. there is an e107 ?
  • Posted 1 Nov 2016 01:41
  • By DanMc
  • joined 8 Jun'16 - 80 messages
I have an operator complaining he's getting a code c107 during his deliveries. Info regarding this code will be much appreciated
  • Posted 29 Oct 2016 04:10
  • By buddy84
  • joined 17 Feb'16 - 12 messages
Anyone know what a code c107 means?
  • Posted 29 Oct 2016 04:08
  • Modified 29 Oct 2016 04:08 by poster
  • By buddy84
code E118 is for the relay being stuck open E115 would be the coce for bad batteries.
  • Posted 14 Nov 2015 04:28
  • By walt_r
  • joined 14 Nov'15 - 4 messages
  • Newfoundland and Labrador, Canada
PM me
  • Posted 24 Mar 2015 04:04
  • By joe_r
Anyone have the break down of the handle stem or parts manual for this unit. Raymond 102t-f45l
  • Posted 21 Mar 2015 05:11
  • By crown619
  • joined 28 Aug'14 - 26 messages
Code E118 Master Control Relay K4 Welded
As stated before, remove the handle assembly from the drive unit, and inspect for shorting wire's inside the handle stem where they pivot by the switches, and also inspect the motor/brake cables where they go down through to the motor/brake.
Also check the K4 relay its the little black one between the horn and motor controller. It should have a diagram on the side of it to show you what each terminal is.
Check everything on the K4 circuit, pump contact, brake, lower sol valve, horn
Also code E115 is not in the manual,
E115 Contactor Off, Welded or Missing, or Faulty Power Amp
Description - Controller could not close contactor (contactor off), contactor welded, or contactor missing.
  • Posted 25 Mar 2014 04:41
  • Modified 25 Mar 2014 04:46 by poster
  • By patrick_b
  • joined 10 Dec'11 - 30 messages
  • Alberta, Canada
@ RAYTECH
Yes I am sure the E118 code does not appear in the manual. It is uslly caused by bad batteries but in this case the batteries are not badd
@stam - Do you recall which 2 wires were the problem.
  • Posted 25 Mar 2014 01:58
  • By joe_r
wiring under the handle stem can get rubbed as the steer arm turns left and right.
I had one like this once and it would only trip an error code once and a while, 2 wires had the outer shielding worn down and the copper wires would touch the frame intermittently.
  • Posted 24 Mar 2014 23:57
  • By stam
Are you sure on that code ? I have no E118 for a model 102XM
Undo that harness so you cab "touch" each wire lightly to get a code or error
  • Posted 24 Mar 2014 12:57
  • By EasiTek
