Hello Guys, We have the above machine in our workshop to repair the wet disc brakes. According to the manual I have we have to refill it with 0.18L of SAE 80W oil. Now if we fill it the mentioned oil type we have a problem that the machine is moving with a lot of shocks in forward and reverse, after some braking it is going normal. Can someone confirm that it is the correct oil type and if is help me with this problem?
Kind regards
Marc b
Hello RCAV8TOR, thanks for advice will control it first thing on Monday.
Kind regards
marc b
Check your free travel of the rod coming from the brake master cylinder. I have seen where the brakes get tight from this not being adjust correctly and or the master cylinder not bleeding off.You should be fine with the selection of gear oil installed.
Thanks guys for the help. We installed new brake disk and springs and clips. we also removed the handbrake cable but that was the same result. We didn't make the disk wet with oil but ones there installed and filled with it that can't be the problem anymore I believe. For me it gives me the feeling that the disk not realising fast enough because the oil is to thick.
any comments are welcome.
Marc b
Make sure your park brake cables are not over tight. I put 80-90wt gear oil in the ones i build. When building the brakes did you soak the disc or put together dry? Did you install the release springs properly?
