Trouble shooting Manual Toyota 7BWS13
Gentlemen, I would greatly appreciate a trouble shooting manual for a Toyota 7BWS13 walkie stacker. The operator manual tells you what the codes are but that is all. I have a C77 code for the lift/lower rocker, I have replaced but still no joy.
Thanks
  • Posted 26 Feb 2014 01:11
  • By Fritz12
  • joined 10 Dec'13 - 9 messages
Fritz12
It appears the you have to have the service key or truckcom software and cable to see how the etac and controller are communicating. The only other thing I can think of is switching the handle head with another truck to see if the problem follows it.
  • Posted 6 Mar 2014 10:17
  • By rogeriwt
Thank you Roger, I appreciate anything you can find out for me
  • Posted 6 Mar 2014 01:22
  • By Fritz12
Fritz12
It looks like it should be plug and play. I am assuming that the wiring from the etac card to the bottom of the handle is good. I am going to do some more looking but the only thing I see for that code is either the switch/pot or the etac card. It looks like you need a service key to see if the etac is communicating with the controller.
  • Posted 5 Mar 2014 20:25
  • Modified 5 Mar 2014 20:39 by poster
  • By rogeriwt
the truck traction is fine, will not lift or lower. The only code is C77. I took the handle apart and checked the connection of the rocker to the board-was good, I also replaced the rocker (pot) with new. the lift pot actually has its own circuit board as well as plugging into the tiller head circuit board. If it needs calibrated, I could sure use that information.
Thanks for your help. I could use anymore help on this issue.
  • Posted 5 Mar 2014 00:51
  • By Fritz12
Fritz12
What is the truck doing? What are the symptoms....
is there power steering on this model?
This is clone of a Raymond RAS25 stacker
Code is for Lift POT, not switch
Lift / lower pot is out of neutral...it's unplugged or shorted
Could be bad Vehicle manager
cant see where lift pot is, have Raymond manual But C77 code has no trouble tree to test...
  • Posted 4 Mar 2014 11:33
  • Modified 4 Mar 2014 12:06 by poster
  • By EasiTek
I really need some help with this gentlemen
  • Posted 4 Mar 2014 00:08
  • By Fritz12
Fritz12
Toyota launches three new stackers Columbus, IN, United States
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
