2.0 mazda engine
Yale GLC030, engine 2.0 mazda, starts and idles great, accelerate to high RPM, runs smooth for about 25 seconds then starts to brake up , slows down almost to a stall then after about 5 seconds picks back up to high RPM and does this over and over like clock work. Any suggestions.
  • Posted 15 Oct 2013 09:36
  • Modified 15 Oct 2013 09:40 by poster
  • By Prancer
  • joined 12 Oct'13 - 48 messages
berwinten@msn.com
Showing items 1 - 20 of 27 results.
didn't matter, warm or cold, head gasket look good. My thoughts are that the black jell might of swelled up when hot and reduced air flow around the intake valves.
  • Posted 27 Nov 2013 07:21
  • By Prancer
berwinten@msn.com
When did the symptoms appear- when engine was warm or cold? Perhaps it was a head gasket issue ???
  • Posted 27 Nov 2013 01:48
  • By bbforks
Machine shop said the only thing he found was a black jell around the valve seats and stems, seals were real bad and a lot of oil around the valve seat area. Guides and springs were good.
Installed another head on another unit doing the same thing and both engines are running real good.
  • Posted 26 Nov 2013 08:59
  • By Prancer
berwinten@msn.com
Ya know, we just had a similar problem on a Toyota 4Y. Found a few things wrong.
1. The last time the head was refurbed the machine shop did not tip the valves so the exhaust was a bit longer than the intake.
2. The valve springs were wore out not allowing the valves to return to rest position when the engine was hot.
Engine has about 11K hours on it. Just some thoughts for ya.
  • Posted 12 Nov 2013 04:20
  • By d_rad
  • joined 7 Jun'13 - 9 messages
  • Minnesota, United States
Visual inspection showed the valves were saturated with oil and lots of carbon build up on the valve and around the seat. I'll take the head to a rebuilder where the guides, stems and seats can be inspected. I will post the find.
  • Posted 11 Nov 2013 21:20
  • By Prancer
berwinten@msn.com
Did you find anything wrong with the old head under examination? Would like to hear what you found- your symptoms were so strange.
  • Posted 11 Nov 2013 06:27
  • By bbforks
After replacing the head the engine runs good, no problems
  • Posted 11 Nov 2013 00:44
  • By Prancer
berwinten@msn.com
I am in the process of replacing the Head with one that was working well in a hyster unit. Transmission went out on it. I will post the results when I have tested it.
  • Posted 9 Nov 2013 10:08
  • By Prancer
berwinten@msn.com
Im thinking the valves are sticking somehow.
  • Posted 9 Nov 2013 02:43
  • By mrbob
  • joined 19 Feb'13 - 118 messages
  • Hawaii, United States
I tried the fuel spray test, it choked off, I changed the PCV valve with one from a working unit, no change.
  • Posted 21 Oct 2013 11:21
  • By Prancer
berwinten@msn.com
Just had a Cat with extremely strange symptoms. Engine would run good ( at any given rpm), then suddenly die off, some times to a stall, other times it would catch at the last moment, then run good again. There was no rhythm to it though- turned out to be a faulty PCV valve. I thought of your situation. I simply removed the PCV valve, plugged the hose & ran the engine- symptoms went away. This is of course after checking all the usual suspects & then pulling my hair out- this really stumped me- never saw a PCV do that before
  • Posted 21 Oct 2013 02:44
  • By bbforks
I would do one more test before taking the head off. Make it act up, and as it's sputtering, spray some flammable brake clean in the air intake and see if it trys to run right, to prove it's not a fuel starvation problem. It just seems if it is a valve problem it would skip regularly and not rev up and then slow down and skip.
  • Posted 21 Oct 2013 01:40
Thanks, I will make them aware of that.
  • Posted 20 Oct 2013 11:18
  • By Prancer
berwinten@msn.com
and consider the reasons an exhaust valve may 'burn' and prepare the customer for purchasing an exhaust system as well as head overhaul.
Also I have seen a few of these where the cam pulley for the timing belt had cracked and or had the key way stripped or key broken... it might be worth checking before the head is sent out.
  • Posted 19 Oct 2013 23:31
  • Modified 19 Oct 2013 23:54 by poster
Valve clearance.012 Job placed on hold waiting for customer to approve head removal.
  • Posted 19 Oct 2013 19:31
  • By Prancer
berwinten@msn.com
The engine misses although with a timing light the ignition never misses? Backfiring out the exhaust although the timing stays within spec? I would agree with mrfixit that this has to be a valve issue. Sounds like an exhaust valve isn't seating- as mrfixit suggests I'd check the follower clearance, if that's within spec I'd check all the valve springs. If all looks ok there I'd suspect a faulty valve seat.
  • Posted 17 Oct 2013 00:43
  • By bbforks
I think the next step may be to look under the valve cover. It just has adjustable cam follower rocker arms, not hydraulic, so having valve noise seems strange. Check the valve springs closely and see if the follower clearance is about.010-.012".
  • Posted 16 Oct 2013 23:03
I placed a pressure gauge at regulator and pressure stays steady through brake up. When the engine starts breaking up it misses and pops out the exhaust and the valve train chatters.
  • Posted 16 Oct 2013 22:16
  • By Prancer
berwinten@msn.com
Are you sure it is not starving for fuel due to filter, hose, or tank connector?
  • Posted 16 Oct 2013 20:08
I would do a compression and leak down test on the cylinders and see if you have a valve issue,vacuum will also tell you if you have a valve problem either ones hanging up or burnt???
  • Posted 16 Oct 2013 19:04
  • By kevin_t
