Code 22
Looking for info on this code 22. After heavy acceleration engine goes into idle mode and will not rev up, restart engine and it`s good till next time. ECS system
  • Posted 13 Aug 2013 06:23
  • By BrewCrew
We`re here for a good time
Sounds like that might be the issue. I`ll know better next week and will keep this updated
  • Posted 16 Aug 2013 06:20
  • By BrewCrew
Are you still having this problem? There should be a bolt under the gas pedalwhich is suppose to stop the gas pedal from going to far down if this bolt is out of adjustment it is letting the ha pedal travel to far down which then cuts the power to the pedal, so its unresponsive
  • Posted 15 Aug 2013 23:15
  • By sergio_p
  • joined 15 Aug'13 - 2 messages
From what I can find on the 4Y ECS Engine:
Trouble code 22:
Open circuit or short circuit of the signal line from the water temperature sensor
Engine stop or low idling speed in engine cold state
  • Posted 13 Aug 2013 06:48
  • By kevin_t
Maxlion MTF25-60-2WD
Aichi SR10C1SM
