BT REFLEX error
Hello,
I have error 3:460 on the truck BT REFLEX with S/N 6095594 from 2009.
Do anyone know something about it?
Thank you in advance.
  • Posted 8 Jul 2013 19:48
  • By Dejavu
  • joined 27 May'10 - 40 messages
  • Bucuresti, Romania
It may look like I'm doing nothing, but in my head I'm quite busy.
I have noticed at other sites if the switches are never used they contacts get dirty & the switch sticks / refuses to work.
I usually play a tune on the parking brake using the release switch when I service an RRE, not had an issue on any of the ones on my fleet.
  • Posted 8 Jul 2013 23:59
  • By Forkingabout
  • england, United Kingdom
Maybe some bad contact in the wiring or emergency switch for the brake
Check mail
Regards!
  • Posted 8 Jul 2013 23:56
  • Modified 8 Jul 2013 23:59 by poster
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Hello,
Thank you for the information.
The truck is working as should work every thing is OK.
I will look again tomorrow on the truck maybe it is somethings that I mist. It will be easy if I have the workshop manual and the wiring diagram.
Any way thank you very much.
Best regards.
  • Posted 8 Jul 2013 23:53
  • Modified 8 Jul 2013 23:54 by poster
  • By Dejavu
That button is the emergency release switch for the parking brake.
Using that switch you can either tow / push the truck with the parking brake released OR if you put the truck in emergency mode it will allow you to drive the truck in limp home mode.
  • Posted 8 Jul 2013 23:48
  • By Forkingabout
Hello Nacsand,
I have check everything and it was OK.
In the fuse box under the footstep it is a button and that one it was switched on. I switched off the button and the truck is working fine. I do not now what exactly does that button but the truck is working fine now.
Thanks for your support.
Best regards
  • Posted 8 Jul 2013 23:31
  • Modified 8 Jul 2013 23:31 by poster
  • By Dejavu
Hi,
According to one service bulletin error 3:560 changes to 3:460, so follow 3:560 instructions:
3:560 Break in the parking brake circuit.
Make sure that the brake is released using
the Emergency release switch [S133].
If the brake is released in an emergency:
* Check that the contact [X131] is complete
and that conductor 95 is undamaged.
* Replace MCU.
If the brake cannot be released:
* Check that the resistance in the parking
brake's coil is ~32 ohm.
* Check that there is 48 V at [Q1:1], towards
B- and that conductor 27 is undamaged.
  • Posted 8 Jul 2013 20:35
  • By nacsand_n
  • Madrid, Spain
Gillian Reed Gillian Reed
Board director, UKMHA
Director, ICHCA Australia
Senior manager of powered access business development & technical services North America, Noblelift
VP business development for Europe, Noblelift Intelligent Equipment Co
edition #1241 - 31 July 2025
CeMAT Australia was held in Sydney last week with a larger than usual contingent of Chinese OEMs. Forkliftaction speaks with a number of them to find out why they are targeting the Australian market, and what they feel needs to be done to be successful here. It’s an interesting insight into a shift in the market which is seeing some of China's largest companies making a move... Continue reading
