Toyota 7FGU35 camshaft sensor location
Hello all,
I have purchased this sensor and cannot locate it on the 4.3 GM engine. It is NOT on the timing chain cover. Any help appreciated!! Thanks
SN:63108
  • Posted 25 May 2013 02:13
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
if your trying to measure that signal with a volt meter you probably wont get a definitive reading. It pulses so fast your meter probably doesnt pick it up.
You'll need the diagnostic software to monitor whats going on in the ignition system, it has a graph readout along with digital readings that show that.
Of course there could also be a problem with the pickup sensor on the reluctor wheel.
just a thought
  • Posted 26 May 2013 13:52
Hmmmm..
I am getting a very low voltage out of the purple/orange wire when spinning over (CMP -), but nothing at the grey/ brown (CMP+) wire.
Problem is no/ weak ignition fire and I am thinking the CMP- wire should pulse. Any ideas??
  • Posted 25 May 2013 08:37
  • By Forkliftt
Steve
THANK YOU!!
  • Posted 25 May 2013 04:09
  • By Forkliftt
Steve
check inside the distributor cap ;o)
  • Posted 25 May 2013 03:36
UN Forklift FBT18NQZ1
Load Lifter 2414-8G
Flesherton, Ontario, Canada
Noblelift
edition #1240 - 24 July 2025
CeMAT Australia 2025 has been underway in Sydney this week, wrapping up today, with the main topics coming out of the event proving to be the very predictable automation and sustainability... Continue reading
August 1-3, 2025 - Coimbatore, India
September 18, 2025 - Blair Athol, South Australia, Australia
November 04-05, 2025 - Houston, TX, United States
