Yale ERC060
Anyone know what an error code 95 is on a Yale ERC060 is. We have a Yale model ERC060RGN36TF090 Ser# E108V12388X.
  • Posted 3 Aug 2007 04:31
  • By DAB19560
  • joined 30 Oct'06 - 2 messages
  • Indiana, United States
Thanks Ed. I'll start another thread with my problem
  • Posted 5 Sep 2007 16:18
  • By buddy_w
  • joined 1 Sep'07 - 9 messages
  • British Columbia, Canada
Does the code come up on the dash display or with the hand set tester? When using the hand set, always keep the setting control **** fully clockwise or you will get brush wear codes. They will also remain in fault code memory.
Do these ERC060's not have GE SX controlers?
Today I had a ERC050 with a code #41 which is drive circuit overheating but I'm not sure if it is the armature overheating or the controller overheating. Does anyone know if there is a thermistor in the drive motor? Mike?
  • Posted 1 Sep 2007 14:03
  • By buddy_w
If your truck has the SR/SP controller, the code is "Brush wear, lift pump motor"
If your truck is an EV100 powered unit, it should simply be an internal status code that means nothing.
  • Posted 3 Aug 2007 06:40
  • By mike_n
  • Alberta, Canada
